Teraz jest Pt, 6 lut 2026, 01:15
Utwórz nowy wątek Odpowiedz w wątku  [ Posty: 650 ]  Przejdź na stronę Poprzednia strona  1, 2, 3, 4, 5 ... 22  Następna strona
PostNapisane: Śr, 30 lip 2014, 09:22
Tobie oczywiście wierze, ale im ani trochę. Ściemniacze obiecają wszystko aby tylko odwlec problem.
PostNapisane: Śr, 30 lip 2014, 10:33
jaj tak to myslales :-)
no do tej pory mowili, ze tak ma byc, ze to producent tak chcial, ze to nejest na reklamacju, ten produkt tak a i teraz uz inaczej.
to zobacze po urlopie jak bedze.
PostNapisane: Śr, 30 lip 2014, 20:19
Wiec mamy poprawione moduły Bluetooth które były odpowiedzialne za głupie odtwarzanie od pierwszego utworu
Info po angielsku :
Technical Service Information
Reference Numberr: R056/14
Building group/block: T
Page 1 of 3
Publication Date: 07.29.2014
Change Date: ----
Replaces Reference Number: ----
Affected Models: Mazda6 (GJ), CX-5 (KE)
Affected Countries and Specifications: Europe
Pre-authorization needed: NO
Title:
Changed functions in combination with USB-connection
(only to be used when specifically asked by customer)
Description:
With the introduction of speech enabling the audio functions, some functions of the USB-connection have changed. After turning on the ignition:
BEFORE the modification:
1. The system reads the content of the USB device in order to activate the speech control, during this time playback is disabled (depending on the amount of audio files, this could take several minutes).
2. Playback of the connected device always starts at the first title (independent of where playback was at the time of turning off the ignition).
AFTER the modification:
1. Playback will start after approx. 30 seconds, reading of the remaining titles continues in the background
2. Playback will resume at the location it was stopped when the ignition was turned off
Reason
By introducing the speechcontrol the functions of the Bluetooth/Handsfree module changed, and the USB-connection is controlled by this module.
Changes in the serial(normal) production:
JMZGJ ****** *****
JMZKE ****** *****
Affected FIN Range & Date of Change:
from JMZGJ ***** 100001 - JMZGJ ****** *****
from JMZKE ***** 100001 - JMZKE ****** *****
Replacement part Information
Replacement part-Nr.
GHP9-66-DH0Z
Description
Bluetooth/Handsfreemodule
Number of parts
1
This order must be entered directly through EBK
PostNapisane: Śr, 30 lip 2014, 20:45
Mam nadzieję, że są już wyprodukowane w dużych ilościach, bo zaraz zabraknie. :)
PostNapisane: Śr, 30 lip 2014, 20:52
tombien - to kiedy się widzimy w Opolu na serwisie ? :wink:
PostNapisane: Śr, 30 lip 2014, 21:20
a dopiero co ( w poniedziałek ) byłem w aso na wymiane uszczelki pod maską i znow mam tam jechac ??? znielubia mnie tam :)
PostNapisane: Śr, 30 lip 2014, 21:28
No to jutro dzwonie do Wróbla i do Osin.
PostNapisane: Śr, 30 lip 2014, 21:31
To info jest z Niemiec . Pisze dokładnie ze tylko na zadanie klienta cześć zostanie wymieniona. Wiec trzeba sie upomnieć .
PostNapisane: Cz, 31 lip 2014, 07:07
No to mam zagwozdkę... Bank chce mi dać 130k pln kredytu, akurat na M6 dla mnie lub CX-5 dla żonki ;-)
PostNapisane: Cz, 31 lip 2014, 10:06
bierz na M6 dla siebie :lol:
PostNapisane: Cz, 31 lip 2014, 10:30
Nie no.. nie będę brać takiego kredytu. Tylko chodziło o to, że naprawili jedyną rzecz, która blokowałaby mój zakup, gdybym miał na to kasę.
Ostatnio edytowano Cz, 31 lip 2014, 12:01 przez chmooreck, łącznie edytowano 1 raz
PostNapisane: Cz, 31 lip 2014, 11:01
W Polsce nic jeszcze nie wiedzą. A konkretnie- w BMG Gdańsk konsternacja jak się dzisiaj o akcję naprawczą zapytalem..
PostNapisane: Cz, 31 lip 2014, 11:41
Podobnie u mnie - ASO MT Opole też nic na razie nie wie...
PostNapisane: Cz, 31 lip 2014, 11:44
No to w Warszawie można jeszcze nie pytać
wysłane tapatalkiem z gsm
PostNapisane: Cz, 31 lip 2014, 11:49
To dziwne, w CZ i SK juz maja info
moze niemaja tyle BT modulow :-)
PostNapisane: Cz, 31 lip 2014, 12:02
Mi MT Opole powiedzieli, żebym podjechał, zgłosił, sprawdzą i zaczną procedurę, ale w sumie to też nie za wiele wiedzą.
PostNapisane: Cz, 31 lip 2014, 12:29
Chyba jednak mogliście nie wysyłać tego pisma do Mazdy. W innych krajach ludzie nie mieli pretensji do producenta więc zostaną obsłużeni w pierwszej kolejności ;)
PostNapisane: Cz, 31 lip 2014, 12:33
Powiadasz: "tych VIN'ów nie obsługujemy" ?
PostNapisane: Cz, 31 lip 2014, 13:13
Ja właśnie jestem w serwisie (w innej sprawie), wczoraj o 19.00 ASO dostały emaila w sprawie modułu Bluetooth i moje zgłoszenie gwarancyjne już poszło. :)
Wysłane z mojego HTC Desire 500
PostNapisane: Cz, 31 lip 2014, 13:36
Byłeś w Osinach?
PostNapisane: Cz, 31 lip 2014, 13:50
No wreszcie pozytywne potwierdzenie , dzieki tombien
PostNapisane: Cz, 31 lip 2014, 15:11
tatahani napisał(a):
Byłeś w Osinach?
Nie, byłem we Wrocławiu u Jaremki.
PostNapisane: Cz, 31 lip 2014, 20:21
Powiedziano mi w Osinach, że trzeba do nich przyjechać, oni sprawdzą co jest nie tak, zgłaszają sprawę do centrali w Holandii i jak stamtąd dostaną pozytywną odpowiedź to rozpoczynają procedurę...
PostNapisane: Cz, 31 lip 2014, 20:24
U mnie nic nie sprawdzali - nie ma takiej potrzeby, w biuletynie jest napisane, że zgłoszenie nie wymaga autoryzacji i dotyczy wszystkich GJ do tej pory wyprodukowanych. Jedyne co trzeba zrobić, to udać sie do ASO - oni robią zgłoszenie gwarancyjne łącznie z zamówieniem części. Na to nie będzie akcji serwisowej, kto chce to mu wymienią - procedura taka sama jak z uszczelką maski.
PostNapisane: Cz, 31 lip 2014, 20:29
no to w przyszłym tygodniu jadę....
PostNapisane: Cz, 31 lip 2014, 22:52
i jak zgłoszę ze usb startuje zawsze od pierwszego utworu i nie zapamietuje to juz wystarczy do wymiany ?
bo u mnie nie ma żadnych problemów z bt zawsze widzi szybko sie łączy z kilkoma telefonami
PostNapisane: Pt, 1 sie 2014, 06:43
Wystarczy, u mnie tak właśnie wpisali w zgłoszeniu. :)
PostNapisane: Pt, 1 sie 2014, 06:50
wlasne na toto mnie olali, to bylo o.k, ale jesce zglosilem , ze niedzala snuffle . Robi tak, ze przeskoczy raz a potem znow po kolejke. I to juz bylo do reklamcii :-)
PostNapisane: Pt, 1 sie 2014, 07:41
Jest potwierdzenie od piosadaczy nowych modułów Bluetooth . Odtwarzanie z usb działa , nic nie jest powiedziane o iPod. Podobno nie zapamiętuje opcji shuffle/repeat
PostNapisane: Pt, 1 sie 2014, 07:49
Od: 29.05.2014
Ciekawe czy wymiana modułu BT nie kasuje aktywacji usług Live.
mar00ha
