PostNapisane: Wt, 28 lut 2017, 21:48
Od: 08.01.2017
Witam kolegów mam pytanie ,gdzie jest odpowietrznik tylnej lampy, bo lampa strasznie mi paruje i czy są jakieś inne sposoby na to.
PostNapisane: Śr, 1 mar 2017, 23:29
Condensation/Fog Inside The Front (Headlamp/Headlight) Or Rear (Taillamp/Taillight) – 2004-2016 Mazda
CONDENSATION / FOG IN FRONT AND REAR COMBINATION LIGHTS
2014 - Mazda6 - Body and Accessories - FRONT COMBINATION LIGHT REMOVAL/INSTALLATION
2014 - Mazda6 - Body and Accessories - HEADLIGHT BULB REMOVAL/INSTALLATION
2014 - Mazda6 - Body and Accessories - FRONT COMBINATION LIGHT DISASSEMBLY/ASSEMBLY
2014 - Mazda6 - Body and Accessories - REAR COMBINATION LIGHT REMOVAL/INSTALLATION
2014 - Mazda6 - Body and Accessories - REAR TURN LIGHT BULB REMOVAL/INSTALLATION
Musisz wyjac zarowke a nastepnie osuszyc reflektor zimnym strumieniem powietrza (suszarka). Jezeli po 5-10 minutach skroplona para bedzie nadal widoczna reflektor podlega wymianie.
"In sunny weather or inside a warm garage, remove a bulb/socket and add cold/cool (not hot) air with a hair dryer for approximately 5-10 minutes.
If the condensation/fog clears, it is normal, and the light unit should not be replaced.
If the condensation/fog does not clear, it is abnormal (water entry is suspected), and the light unit should be replaced.
Water entry is where rain water comes into the inner light and stays as waterdrops on the inside of the lens. The possible causes of "water entry" because of a part issue are:
- Poor sealing joint between the lens and housing.
- Missing or poor sealing of gasket. (NOTE: If the light unit was previously repaired and any seals are
missing, this is not covered under Warranty. Contact your DSM in this situation before replacing the light.)
- Cracked lens and/or housing.
- Poor installation of respiration tube at ventilation hole.
NOTE:
Causes of water entry from owner/operator treatment of vehicle (that should be avoided and are not covered under Warranty) are:
The light and the surrounding area receive too much water in high-pressure washing. The lens cracks from using a special cleaning agent with solvent."
PostNapisane: Pn, 13 mar 2017, 22:38
Od: 23.04.2016
Miałem to samo w Seacie Leonie, musiałem przyjechać do serwisu 3 razy i pokazać że mi regularnie paruje po umyciu samochoduj lub nad ranem jak stał na dworze bo inaczej nie chcieli mi nic z tym zrobić złodzieje.
Lublin to nie dziura :)
PostNapisane: Śr, 15 mar 2017, 09:23
Zgadza sie w Seacie Leon z reflekorami LED tez byl ten problem. Mam nadzieje, ze teraz jest lepiej, bo Seat chyba wychodzi na prosta z nowymi modelami.
PostNapisane: Pt, 8 lut 2019, 08:53
Od: 28.03.2017
ponawiam pytanie, czy jest w lampie z tylu w klapie( wersja kombi) odpowietrznik. Dzis na myjni, zauwazylem centymetrowy nalot pary po jednej stronie... Lampa led.
