Teraz jest Pn, 13 maja 2024, 22:34
 Tytuł: Airbox MOD
PostNapisane: Pt, 9 lis 2018, 07:15
Od: 11.10.2018
Greeting!
The internet is full of ideas how to boost, pop up the intake sound,
to sound more powerful, supposedly and performance to be a positive ..
I do not ask for that. I need a quiet and quiet environment.
At Mazda 6,2007 2.0 89kw diesel, I always have a deep tone that I hear. (cca 80-150Hz)
I had two flow pots behind, gave them removed, returned the original ..
The sound is still present.
Today I get caught in the car, trying to figure out if I have a leak from the down pipe, catalyst / dpf .. Everything looks tidy, the sound can not be positioned.
And then - a miracle. Auto on, just touch the gas, "SOUND" appears. 5-6 seconds after I release the gas, the sound goes out. I accidentally press the clutch, the SOUND appears. I let the kettle disappear, a few seconds later, the sound disappears. SEARCHING
The deep, mumble tone comes from the filter intake box, that is, from its suction pipe.
The suction box is original, the "false pod" is a plastic resonator in it.
The phone failed to pick up that sound just as the box is closed, but when I open it, it's clearly heard. Closed mullet, just a little quieter. I want to delete it, the sound.
Video: https://www.youtube.com/watch?v=i7sa_BQoaos
My first idea is inside, underneath the filters on the divine walls, cling to the tall pyramid-shaped sponge.
Please, if anyone has any smarter idea, I would be glad! Thank you
